I used (Dow brand) blue foam and polyester resin and it only melted in about 1/8". i found that if I made the foam the size I wanted the final shape to be the fiberglass would melt in and (stick hard) as well as end up the same size as the foam had been.
It might not be the same for you but thats what worked on my tail.
