Old 09-20-2012, 09:06 PM   #34 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by Jakins View Post
Hmm ok. So I'd I drive real soft. Shifting at or before the shift light I'm good? I heard that coasting in neutral stays in LB is that the same for putting the clutch in 5th? My girlfriend has an elantra with an econometer and I notice when you let off the gas it gets better mileage than neutral. It is an auto but I've heard and believe idle uses more gas then letting off the pedle and leaving it in gear.but you are saying it throws you out of LB?
I don't think the shift light will give u what u need to optimize lean burn time. The LOD and TPS numbers I gave are when using a ScanGauge. I use mine constantly for LOD (load) and the LBN display (lean burn). I display volts and engine temp on the other two.
Coasting in neutral vs. in gear:
At any given moment coasting in gear will use less fuel (usually none) than in neutral with engine idling. HOWEVER the engine braking from coasting in gear usually slows u down so much that it's not worth it. Unless u need to slow for a stop sign or such.
Best is coast in neutral with engine off. No penalty there. Except of course for Honda's lean burn cars, they kick you out of LB if u kill the engine and you'll need to drive 1.5-2 miles to restart LB. Coasting in gear with engine running also seems to disable LB but I haven't fully mapped how that works.
So on my daily 55 mile highway runs, when I'm able to coast, it's in neutral with engine running. It lets me get lean burn back pretty quick after the coast. It gives about 300-375 mpg so I'm happy with that for highway use. On smaller roads I don't usually achieve LB so I kill the engine for coasts.
Coast long and prosper.
The Following 2 Users Say Thank You to brucepick For This Useful Post:
Jakins (09-21-2012), turbovr41991 (10-04-2012)
