Old 09-28-2012, 04:57 PM   #49 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
If those plastic "side" bumpers behind the rear wheel are easy to remove, you could modify them to taper more than they do as well. Worth doing in combination with rear wheel skirts because they'll be able to work with attached flow. They probably have pretty turbulent if not detached flow over much of that surface as-is.
