Old 10-01-2012, 07:34 PM   #49 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by turbovr41991 View Post
My HX engine seems to limit lean burn entry to about 2500 rpm. I have been told that is not normal and I am trying to figure out what is limiting me. After two tanks of “testing “ lean burn at 2500 RPM in 5th gear (or about 75 mph) I can say it stays in lean burn quite well at high speeds.
The stock HX with a final drive of 3.750 (I think) and 14" wheels would have hit 2500 RPMs at a much lower speed than 75 mph. Your VX 3.250 final drive combined with wheels that are 14" instead of VX stock 13" may be the "problem" requiring a significantly higher speed to allow LB ... perhaps there is a way to fool the ECU? What sensors does it use to determine LB?
