Old 10-08-2012, 01:51 AM   #603 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Varn View Post
Just replacing components can get expensive.
Agreed. That's why I like a saying a dude on honda tech uses as his signature file: "test, don't guess."
Originally Posted by Sven7 View Post
I replaced the cap, rotor, plugs and plug wires a month or so ago. Or do you mean the actual distributor needs to be replaced?
I mean MAYBE the actual distributor needs to be replaced. But like Varn said, I'd hope I would keep my patience and test the coil when the car is in fail. When I lost my patience, I replaced an electronic igniter in the dizzy on a hunch that was only partly correct. Only when the new igniter was wrecked by the failing coil did I figure out the root issue. Wasted cash; wasted time.
Sorry this way cool Mad Max project is sticking you right now! Good luck.
