Old 10-10-2012, 10:09 AM   #65 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Allch Chcar View Post
I'm not sure exactly, but I know E50 is about 95.4 AKI Octane while E85 is about 95.6 Octane. I would guess it might be around E20-E30. E10 was 89 Octane before spec blending. I'm more than a little curious myself.
Elsewhere I was reading that 87 octane plain gas when blended with 30% ethanol can vary from an effective apparent octane of 91-100 depending on the alky content of the gas (whatever that means) So I guess the composition of the gasoline blended with the alcohol causes the real octane value to vary wildly due to the cooling and vapor pressure effects the mix has (which are non-linear)
Some gas companies are using this effect to save money by mixing high alkyl 82 octane gas with 10% ethanol to get 87 octane.
Cheers
Ryan
The Following User Says Thank You to rmay635703 For This Useful Post:
Allch Chcar (10-10-2012)
