Old 10-09-2012, 10:06 AM   #61 (permalink)
We're getting below freezing temps with some regularity now so I'm backing off on the strong E85 blends.
Old 10-09-2012, 10:14 AM   #62 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
E85 / E0 87octane blending octanes
I am curious what ratio of E85 to E0 (87 octane) would net you 91-93 octane fuel
Ditto the 87 e10 gas.
I would like to get premium octane without buying premium fuel and am mainly curious what the ratio is.
At one time I thought there was a blending chart somewhere but I can't find it.
Cheers
Ryan
Old 10-09-2012, 10:29 AM   #63 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Originally Posted by serialk11r View Post
I don't think this is actually a good sign, probably means your fuel injectors are maxed out :O
They are'nt maxing out. It's the Bioadapter that's causing it. Maybe wrong settings. Gonna test it and fix
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 10-10-2012, 08:56 AM   #64 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Cheers
Ryan
I'm not sure exactly, but I know E50 is about 95.4 AKI Octane while E85 is about 95.6 Octane. I would guess it might be around E20-E30. E10 was 89 Octane before spec blending. I'm more than a little curious myself.
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
Cobb (01-13-2014)
Old 10-10-2012, 10:09 AM   #65 (permalink)
rmay635703's Avatar
Elsewhere I was reading that 87 octane plain gas when blended with 30% ethanol can vary from an effective apparent octane of 91-100 depending on the alky content of the gas (whatever that means) So I guess the composition of the gasoline blended with the alcohol causes the real octane value to vary wildly due to the cooling and vapor pressure effects the mix has (which are non-linear)
Some gas companies are using this effect to save money by mixing high alkyl 82 octane gas with 10% ethanol to get 87 octane.
Cheers
Ryan
The Following User Says Thank You to rmay635703 For This Useful Post:
Allch Chcar (10-10-2012)
