Old 10-10-2012, 01:00 PM   #70 (permalink)
turbovr41991
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
Originally Posted by Jakins View Post
You could try cleaning your o2 with carb cleaner or air Intake cleaner. I'm going to do the old ghetto trick of using a spark plug defouler to get the o2 out of the direct flow. That's supposed to work. I have friends with aftermarket headers on their cars so I've been asking around for their stock manifolds. I'll deffinetly let you know what I figure out. But man. This mpguido is sweet. I'm almost positive I was in lean burn on the highway. But In Austin Texas it's very hilly and I get way more milage from pumping the hills then using lean burn it looks like. But still I'm having so much fun pushing this thing to the limit!
I just ordered a new one. I had a discount coupon for rock auto and it was only $30 for the OEM plug. I have seen the defouler trick, but that is more for Cat delete isn’t it? From what I remember people use the trick to limit exhaust to the rear O2 sensor which causes the check engine light not to come on.
Originally Posted by seeodywhy View Post
I checked the wiki and it doesn't have the hx listed. Can you share what values you use? I wanted to install this today but I am having trouble finding that values. Also, did you have adjust the values you used much from the original.
This is for a 97 HX 5 speed manual.
VSS setting: 8208 pulses/mile
Fuel: 298378367
I have only adjusted the VSS a little to be in more alignment with GPS distance. It was pretty close at this setting and is more of a fine tuning than anything.
Mpguino calibration - EcoModder
