You mentioned engine air flow earlier.
You can run radiator hoses to wherever you need, the rad doesn't have to be right by the engine. That might free up some of the decision process. However for a FE car, remember a long hose run will increase total coolant capacity slightly so warmup time will be slightly longer.
I've seen mid or rear engine performance cars in the lot at work with the radiator in the front. Sorry, can't recall if they were Porsches or Lotus. In nice weather, we often have several of both in the lot! An odd perk of working where jet engines are designed built, more than one employee is seriously interested in speed for some odd reason.
Coast long and prosper.
