Old 10-30-2012, 11:30 AM   #8 (permalink)
oil pan 4
Wider tires wont hurt you as much as you think they will.
If you are going to run a lower bumper or air dam it will matter even less.
Another good thing about running larger tires is they almost always have higher load capacity.
What does the stock intake look like?
Rammed air and cold air intakes are your friend.
Water injection is nice for loaded hauler diesels or diesels that see a lot of highway time.
Water injection - EcoModder
I'm going to put the front lower, may off set it with air bagged springs for when I need some more clearance, which is kind of rare.
