Old 11-06-2012, 12:10 PM   #146 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Chris D. View Post
I'm guessing you've never driven a truck with the tailgate down and went over speed bumps.
That will end up destroying the foam over time unless he plans on mocking his shell in glass or bracing the gate so it doesn't move.
I think that ditching that much weight will help far more than a body panel being used as a bumper
Post #134 show photos of a welded steel frame bolted to the bed that locks the gate down. IMHO the added length will show more gains at the pump than the weight savings from losing the gate, at highway speeds. I think OP wanted it long enough to sleep in too.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
