Old 10-29-2012, 09:39 AM   #141 (permalink)
I'm not talking about a thick layer of epoxy, just not absorbing some of the excess the way you described, to have a "wetter" layup. Epoxy is pretty flexible, much more so than polyester resin.
Old 11-04-2012, 09:04 PM   #142 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
I think I would have ditched the tailgate for weight savings since you really can't use it..
Old 11-05-2012, 03:48 AM   #143 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
I can think of 3 reasons to leave it on. First to protect the bottom of back of the cap. Second in a rear end collision it adds some protection. Third it keeps that back angle on bottom to less than 10 degrees which is optimum for a rear diffuser area.
Old 11-05-2012, 06:24 PM   #144 (permalink)
EcoModding Minded
Chris D.'s Avatar
I'm guessing you've never driven a truck with the tailgate down and went over speed bumps.
That will end up destroying the foam over time unless he plans on mocking his shell in glass or bracing the gate so it doesn't move.
A down tailgate wont give you any protection if it just swings upwards with little to no force. Most of everything that's going to hit him will more than likely be a passenger car and the tailgate will just bounce upwards off the rearward cars fascia panel.
I think that ditching that much weight will help far more than a body panel being used as a bumper.
I own the same truck he has and I'm on my 4th rear bumper from rear enders. Silver is a color that just blends in and doesn't get much recognition.
A simple piece of plywood could sufice.
I did something simple and cheap that could be used to subframe the tailgate.
scroll down, mite give ya some ideas. I'm sure that foam isn't cheap and the elections are almost over with, coroplast heaven!
http://ecomodder.com/forum/showthrea...er-2560-2.html
Old 11-06-2012, 08:38 AM   #145 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
You could git one of these to prevent them rear enders...
SUPERBUMPER Hitch Step - Stops Rear End Collision Damage.
I have the Sparebumper one on my truck.
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 11-06-2012, 11:10 AM   #146 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Post #134 show photos of a welded steel frame bolted to the bed that locks the gate down. IMHO the added length will show more gains at the pump than the weight savings from losing the gate, at highway speeds. I think OP wanted it long enough to sleep in too.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 11-06-2012, 03:15 PM   #147 (permalink)
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed
90 day: 34.62 mpg (US)
Yep, the tailgate has to stay. This is supposed to be an extended camper, so if I took it off, I'd just have to replace it w/ something else to make the bottom of the bed back there. And then I'd have to worry about where to store the tailgate in my garage.
The bumper will still be there, too. I've been rear-ended a couple of times, too... you can probably make out the dent in the passenger side of my bumper.
I got all the wiring done for the new taillights this weekend. I already had a trailer wiring harness installed, so spliced into it's extensions for each of the tail-light pods and added a 6-connection plug to each side. The new lights just plug plug in.
Lastly... I added another layer of foam to each of the side panels for the extension and pretty much got the driver side panel shaped how I want it. I'm going to rough in the shape of the passenger side next and try and get them symmetrical when I finish both sides.
Fiberglass attempt #2 will be very soon...
The Following User Says Thank You to a8ksh4 For This Useful Post:
KamperBob (11-07-2012)
Old 11-06-2012, 05:16 PM   #148 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Looks like a HMMWV!
Old 11-06-2012, 05:20 PM   #149 (permalink)
B.O. Zen
Gotta love that simple boxed construction, eh.
Old 11-06-2012, 08:55 PM   #150 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Looks good, I love how this is turning out, great work. I can't wait to see it all come together.
