Originally Posted by chrisgerman1983
I was thinking the same thing, but as a business there are a lot of liability issues to worry about. If you or I build a grill block and belly pan and the car overheats and blows a head gasket it is our own fault. If somebody buys a car that they expect to perform flawlessly and the same happens then it is a big problem. Or if a belly pan comes loose and takes out a brake line... sometimes keeping it "simple" (not that ECU reprogramming is simple) is the best way.
Most aftermarket companies get around this by saying “not for street use” or “for off road use only.” Expect the same to be done here. Although many people buy the products and use them on their street cars, the legal responsibility falls on the driver for using said products on the street.
