Old 11-14-2012, 10:08 AM   #92 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Impressive MPG numbers considering the high RPMs.
Remember that with only a 2.588 gallon fill, there could be significant pump error. It is not good data, it is just what I have. Do these cars have a lean burn function in the ecu? Is that more standard now than in the 1990s? I also noticed that it seems to cut fuel off in gear under deceleration even at low rpms. I tested that by coasting to lights in neutral and in gear and found that at very slow speeds, under 25 mph, I could make the car's instant mpg gauge read higher mpg by shifting back into gear from a neutral, idle, coast down. Also, AC makes a big difference in this car I saw shifts of 10-15 mpg in the instant numbers whenever I turned on/off the AC.
