Old 11-24-2012, 03:02 AM   #103 (permalink)
turbovr41991
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
Originally Posted by Rusty94cx View Post
the Eco shop as you probably have seen has the hx ecu now. I want to know what they are running and what software.
They are using an OBD2 to OBD1 jumper harness and a P28 or equivalent ecu. In talking with them, they said I could just get a jumper harness and use the VX ecu (as you suggested), but it would not be ideal and for the money, I might as well get a tuned ECU for optimal lean burn specific to the HX.
I've found that the springs on these older Honda clusters tend to get weaker over time which results in the speed reading high. To fix this on my cluster I simply popped the needle off and stuck it back on 3mph lower.
Thos would make a lot of sense. Honestly, I do not mind it reading higher than what I am going. I have a hard enough time convincing my wife we are going “fast enough.” This miscalculation actually aids me when I can point and say “look we are going 65 mpg” when we it actually is reading 63-64 mpg and my real speed is right at 60. lol
