Old 11-26-2012, 01:05 PM   #26 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by PaleMelanesian View Post
This may be a silly question, but did you check the brake disc shield behind the front discs? I bumped mine when I replaced the half-shafts, and it was scraping on the back of the disc.
Thanks for this and your PM. I didn't check, but I will when I go back into this, maybe this coming weekend. But I think it's unlikely, since the sound is pretty much unchanged. A friend on facebook from a Bonneville racing family suggested maybe its some sort of "transfer bearing" in the transmission, connecting the drive axles to the gearing. But he agrees the hub bearings, the "races", are the most likely culprit. I'll test more this weekend and report. Thanks for following the tale.
