Old 12-04-2012, 03:48 PM   #24 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
That being said, ALL modifications have to be done with safety in mind. You shouldn't have anything flying off your car. If you don't know if it is going to stay attached you should redesign it to be sure, and then test it in a safe manner. I'm happy to say this is virtually a non-issue on this board and I can't even think of a time when I read some mod spontaneously failed in any bad way.
Actually, on a TEST RUN on a deserted road by the ranch, I was testing to see how FEW mounting points I needed w/ a new/redesigned install on my front underbelly pan.
and yep, at about 40mph it popped out. But that was why I was testing it.
TO make sure it was mounted securely enouch to withstand the air force that blew thru the lower grille opening.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
