Old 01-24-2013, 03:52 PM   #21 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
if you look at the diagram posted above, it you cut the wire not in the spot listed you will kill the whole fuel system, not just the injectors. you also kill power to the immobilizer and then need to cycle the ecu. just killing the injectors will not cause the issues listed by vman455.
