Old 02-23-2013, 11:34 AM   #25 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I accessed the injector power lead at a large connector (my Civic is '97, Gen 6) near drivers side hood hinge. Aside from having to snake a wire through an existing rubber boot in the firewall, the job was not too difficult. I definitely don't relish the thought of working through stuff behind the glove box.
Here's the post.
http://ecomodder.com/forum/showthrea...tml#post175914
Go to the first post in thread to see photo of the connector.
The link above tells which wire it is - it's not the fat one easily visible in photo.
If you're not handy with relays like I am, there's nothing wrong with using a simple switch on the dash, as long as you have good solid connections at every point along the way. Probably should use a wire just a bit thicker than what you cut into, because you're adding length to the run. My switch is a toggle and I like it. Flip it off to kill, flip it on again right after engine dies to re-enable fuel injection. That way when you bump it to start, it will catch. If you use a momentary disconnect instead, then you need to hold it down till the engine dies. That's less convenient, imho.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
j12piprius (01-26-2015)
