Old 03-02-2013, 03:11 PM   #23 (permalink)
oil pan 4
The diesel cycle starts off with isentropic compression, then some constant pressure heat addtion followed by isentropic expansion.
With the isentropic compression and expansion and constant pressure heat addition that means the more air you can stuff into the engine the better off the entire cycle is for making both power and effiency.
You can do this with a supercharger to some degree, very well with a turbo and some what with water injection or with a mix of them.
3 psi doesn't sound like much. Where I am the pressure is about 12.5psia.
By adding 3psig at 60mph that is putting almost 25% more air into the cylinders of my air loving diesel engine.
