Originally Posted by Blue Angel
After seeing ROB's renditions, an afterthought would be to have the lower grille block centered with a small inlet on each side, then the plate could go on in the middle?
Unless the Insight is like other Hondas with the small rad offset to one side, then my idea is poo...
Or two grill blocks with the hole centered.
I like the look of the grill blocks, I vote for either color matched or black. And, yes, I realize my vote doesn't count
