Old 03-11-2013, 02:51 PM   #51 (permalink)
90 day: 51.82 mpg (US)
I do like that 2nd one.
One fly in the aesthetic ointment I forgot to mention: the front licence plate has to go back on, and it'll be mounted just right of the car's centerline on the lower block
Old 03-11-2013, 03:39 PM   #52 (permalink)
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
i still dont think it would look that bad
you could make a mounting ring to overlap and secure the plate?! would be a clean flush install if you wanted to spend a couple more hours on the overall porduct
EDIT: does your jurisdiction/city allow the Tinted plate covers?! It may help, not stick out like a pimple
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 03-11-2013, 04:14 PM   #53 (permalink)
Blue Angel's Avatar
Previous Car - '12 Chevrolet Cruze Eco MT
Team Chevy
90 day: 44.29 mpg (US)
535d XDrive - '16 BMW 535d M-Sport
After seeing ROB's renditions, an afterthought would be to have the lower grille block centered with a small inlet on each side, then the plate could go on in the middle?
Unless the Insight is like other Hondas with the small rad offset to one side, then my idea is poo...
2016 BMW 535d
4100lb XDrive Eco-Yacht
Old 03-11-2013, 06:05 PM   #54 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Or two grill blocks with the hole centered.
I like the look of the grill blocks, I vote for either color matched or black. And, yes, I realize my vote doesn't count .
Old 03-12-2013, 10:04 AM   #55 (permalink)
For simplicity, i love the look of the offset opening, it gives it a almost factory "theres something amazing about this car that you never knew" type presence... asymetrical is overated
Old 03-12-2013, 10:11 AM   #56 (permalink)
I like it offset for that reason, too.
But the engine radiator is offset on that side, so it's functional too. I could have centered the small opening on the left side, but then I would have had to make a shaped plug to stick on the extreme left to guide the air into the reduced opening.
Old 03-12-2013, 12:14 PM   #57 (permalink)
not to mention, once you boattail it, everything qwerky will look right at home and proper overall.
Old 07-14-2013, 09:52 AM   #58 (permalink)
day-glo it is
Fluorescent green FTW!
(Not photoshopped.)
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
Blue Angel (07-15-2013), Flakbadger (07-14-2013), HyperMileQC (07-28-2013), Insight for life (07-14-2013)
Old 07-14-2013, 10:44 AM   #59 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Wow that is obnoxious and gorgeous all at the same time.
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
Old 08-05-2013, 08:26 PM   #60 (permalink)
Could you elaborate on what materials you used for the surface finish? Paint (spray paint?), putty, sanding, epoxy? Just to make the process idiot proof for someone like me. I also need to make a side mirror plug using the same technique.
Bondo?
I try to be helpful. I'm not an expert.
