Old 03-13-2013, 02:01 PM   #17 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Pale, Thank you for your detailed original post. I also experimented with red LED tail and brake light replacement bulbs. I tried yellow for the turn signals but got the dreaded hyperflashing. One of those bulbs is now the outside light on my pop-up camper (I can leave it on without running down my 12v deep cycle battery). I found the LEDs to be not as bright as the original filament bulbs and wanted a different look so I sprung for ebay Lexus style LED taillights. These replaced the whole taillight housing but still use filament bulbs for turn signals. They are very bright from the rear and I feel safer. Just my 2¢.
I ordered my replacement LEDs from the Superbright website.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
