Old 06-18-2008, 10:37 PM   #82 (permalink)
hypertex
No gain here
Originally Posted by Coyote X View Post
The other thing would be using some relays to switch them out you can add several silicon diodes in line. You get a .7V drop across a diode so add 5 of them in series will drop you 3.5V. Just make sure to pick big enough diodes to handle the load.
Originally Posted by basjoos View Post
Coyote X, good idea about using series connecting the headlights and also using doides to customize the voltage drop.
Your alternator/battery will still have to provide the standard voltage. Yes, headlights are dimmer but there is still 12+volts feeding the diodes. Why not just use a smaller fuse or feed wire to limit the draw?
1987 Turbo Sprint
