Old 12-14-2007, 03:19 PM   #11 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
After you swap out to LED park lights if you want to reduce the headlight load you can wire up some relays to switch them to series load instead of parallel. That will make them dimmer but not really dark. It will cut the load in half though
The other thing would be using some relays to switch them out you can add several silicon diodes in line. You get a .7V drop across a diode so add 5 of them in series will drop you 3.5V. Just make sure to pick big enough diodes to handle the load.
Old 12-14-2007, 03:20 PM   #12 (permalink)
90 day: 51.82 mpg (US)
I've heard of an instance where a university team solar car was forced off the road due to rubbernecking. Ended up catching a culvert and flipping the solar car. Fortunately nobody was hurt.
EDIT: the comparison of your Civic to a solar car (in terms of aero optimization) isn't that much of a stretch either either.
Old 12-14-2007, 04:31 PM   #13 (permalink)
Peakster's Avatar
Red Jeep Patriot - '07 Jeep Patriot
90 day: 25.14 mpg (US)
Beige Ford Ranger - '95 Ford Ranger XLE
Whatever happened to your additional 'wind screen' :
Old 12-14-2007, 04:33 PM   #14 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Rain?
Old 12-14-2007, 04:41 PM   #15 (permalink)
Peakster's Avatar
Originally Posted by SVOboy View Post
Rain?
Mmm. I don't think so. Not according to this previous post by basjoos:
The second windshield added about 4mph to my terminal velocity on the "calibrated" downhills on my drive. I drove through some light rain and didn't even notice it on the vinyl other than the occasional drop running back along the vinyl. Most of th rain (and bugs) follows the smooth airflow over the vehicle. And best of all, no evidence of the "A" pillar vortex based on the behavior of the water droplets on the front side windows.
Old 12-16-2007, 07:44 PM   #16 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Coyote X, good idea about using series connecting the headlights and also using doides to customize the voltage drop.
The aero benefits of the "second windshield" (by eliminating the "A" pillar vortex and smoothing the airflow over the front of the car) were undeniable, but I had some operational problems with it when operating in cold rainy weather. I'm in the process of replacing the clear vinyl on the "windscreen" with Lexan. The vinyl was clear enough when looked at straight through (90 degrees), but was hazy when viewed through at an angle (30 degrees) as it is near the bottom of the windscreen. It also had a tendancy to overwealm the Fog-X and fog up on the inner surface when driving in cold, wet conditions. The Lexan should take care of the low angle visibility problem and I need to get a good watertight seal along the front and sides of the "windshield" so water can't find its way onto the hot hood and end up condensing on the cold inner surfaces of the "windshield". Also considering adding a windshield wiper to the "windshield" to placate any cops that might freak out at a car driving in the rain without wipers, even if I don't really need them.
aerocivic.com
Old 12-16-2007, 09:28 PM   #17 (permalink)
The Mighty Mira - '92 Daihatsu Mira
90 day: 61.32 mpg (US)
Basjoos, you might want to stick a sock full of crystalline kitty litter (it's silica gel, the cheapest source you can find) somewhere in that space to get rid of any lingering moisture that finds its way in there.
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
Old 12-26-2007, 07:20 AM   #18 (permalink)
I read this and was so impressed I had to write about it on my blog.
You can read my thoughts at http://www.energyrefuge.com/blog/caf...-be-that-hard/
Old 12-27-2007, 07:26 PM   #19 (permalink)
Darxus's Avatar
Nice.
I was recently thinking about wheel spoilers and I thought of something I think is relevant.
Your front wheel spoiler mostly pushes air down, where it will end up hitting the tire (or ground) still anyway. I believe that won't help you any, and that it would be more efficient to just push the air directly to both sides of the wheel. Possibly more to the outside of the car than under the car due to the rest of your aerodynamics. So you would have a wedge where the leading edge is a vertical line.
And I would expect you to benefit from putting another set of spoilers behind the rear wheels (working well with your dual layer side skirts).
Of course I have no idea if these would give you enough benefit to be worth you doing.
Old 12-27-2007, 07:33 PM   #20 (permalink)
That's a good observation for behind the rear tires. But do you mean to add a "boat tail" rather than "spoiler"?
You'll see wheels/tires effectively boat tailed on this car:
http://www.design-classic-cars.de/auto-union/stuck1.jpg
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 12:14 PM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 12:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
