Thread
Kill Switch (EOC): Where did you install your activator? And what did you use?
03-28-2013, 03:30 PM
60
permalink
Shortie771
Eco Sol
Originally Posted by
mozul
I added my engine off/start switch to my Spitfire this weekend.
Here are the relays in the engine compartment
Engine Off/Start relays
by
Mozul
, on Flickr
And this is my switch. I have since turned it 90 degrees to the left to be between my forefinger and thumb.
Engine Off/Start Switch
by
Mozul
, on Flickr
The switch is a SPDT Momentary mini switch I got from Frys Electronics.
(ON) OFF (ON)
The
relays I got from Amazon
as well as the sockets for the relays
Is this switch for the injectors? Does it also kill your electronics? I don't want to have my stereo cut out every time I kill it.
Best Tank =
42.72 mpg
(in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Shortie771
View Public Profile
Send a private message to Shortie771
Find More Posts by Shortie771
