02-08-2013, 02:56 AM
#51 (permalink)
Here is a photo of my kill switch placement.
If you want some more details see this post in my thread:
http://ecomodder.com/forum/showthrea...tml#post355489
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
02-08-2013, 06:41 AM
#52 (permalink)
Wow! I really like how you did that!
Could you have run the wires under the boot?
02-08-2013, 06:49 AM
#53 (permalink)
It's a photo from fitting the knob back in the car. I'm planning to connect all the wires on weekend.
02-08-2013, 07:39 AM
#54 (permalink)
Wanting more for less
Are you planning on using the other side of that rocker for something else?
02-08-2013, 08:15 AM
#55 (permalink)
Scandinavian creature
Yea i was thinking that too, what's the purpose? Turbo boost?
But it's the best looking so far.
02-08-2013, 08:27 AM
#56 (permalink)
Thanks guys. It will be for killing the engine and for starter as well. So I'll be able to kill and start the engine without moving my hand from the shift knob
The Following User Says Thank You to AndrzejM For This Useful Post:
02-08-2013, 11:55 AM
#57 (permalink)
The cool tricks that you can do with a manual transmission!
02-08-2013, 03:08 PM
#58 (permalink)
5 Gears of Fury
I was going to use one of these as I have a spare one, and they are made to mount onto a shifter already. But seeing as it is designed to be "Off" most of the time and only used for short periods of time, I don't know if that would affect it's reliability if it was used mostly in the "On" position with current going through it. I am thinking a little bit beefier switch might be the way to go instead.
ROLL/CONTROL SWITCH | Hurst Shifters :: Automatic Shifters, Manual Shifters, Paddle Shifters, Shifter Knobs and Handles
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
03-11-2013, 04:34 PM
#59 (permalink)
Engine Off/Start switch on a spitfire.
I added my engine off/start switch to my Spitfire this weekend.
Here are the relays in the engine compartment
Engine Off/Start relays by Mozul, on Flickr
And this is my switch. I have since turned it 90 degrees to the left to be between my forefinger and thumb.
Engine Off/Start Switch by Mozul, on Flickr
The switch is a SPDT Momentary mini switch I got from Frys Electronics.
(ON) OFF (ON)
The relays I got from Amazon as well as the sockets for the relays.
Reason: Added links to relays and sockets and details about the switch
03-28-2013, 03:30 PM
#60 (permalink)
Eco Sol
Originally Posted by mozul
Is this switch for the injectors? Does it also kill your electronics? I don't want to have my stereo cut out every time I kill it.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
