The true VX wheels were 13" and I doubt they would fit a '95 EX which came standard with 14".
However the '96-'00 HX had wheels very similar to the VX design, except an inch larger. Should fit your EX just fine. It would be worth your time to measure any 14" rim flange to learn its actual diameter. Then check the so-called VX rims and see if maybe they are 14" HX.
Coast long and prosper.
