Old 04-02-2013, 07:45 PM   #8 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
ok,
1. check out the clearance on the top of the tire to the bottom of the strut base.
2. crank the steering hard left and right and see how close you are to anything.
3. if the is clearance get back with a rough estimate.
4. then will look at tirerack.com for the next size taller
http://ecomodder.com/forum/showthrea...s-24006-3.html
see post/pics at #30. That is the clearance to the strut mount WITH the taller tire!
However, the way the fender well was designed, there is about 1/4 of an inch at the front edge.
So that was the tallest tire i could go with!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
