Old 04-08-2013, 09:14 AM   #10 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
If the 8th gen Civic Si has a sixth gear with ratio 0.0659 and a final drive 4.765 and my sixth gen DX coupe originally had a 0.702 fifth gear and a final drive 4.058, then your engine turns 3.14 revolutions on the freeway for every 2.85 in the older DX. Your engine will turn about 10% faster than the sixth gen DX. You will be in the 3000 rpm range at 65mph, I would guess. Taller tires would help.
Being able to cut the engine and glide is a key advantage of the manual. You'll likely get 10% FE improvement from that alone, maybe considerably more depending on conditions and your determination.
Still, if you are a highway driver and not devoted to hypermiling, the EX is a better choice in terms of FE.
