Did you use the search function for this site, in the above left corner? If not, do that first. This has been discussed many times. I think you're having trouble getting responses because it has been talked out so often. Here is just one search result I got:
http://ecomodder.com/forum/showthrea...html#post22445
Read the whole thread and you'll see that the answer sorta is and has to be: "it depends upon your car and your driving conditions."
But do your own search. I can tell you that if you check my garage page, you'll find I linked to my WAI test under my listed current mods for my '98 Civic DX.
BTW:
Rig something up with dryer vent tubing and duct tape, you would be out like $9 then at least you would know one way or the other, something well worth it to know.
That's what I have now.
james
