Old 04-22-2013, 01:52 PM   #68 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Hi Jim...
Originally Posted by 3-Wheeler View Post
you used a camera this time instead of the web-cam. Is there a reason why you chose the camera?
The web cam I had been using died. Plan B: I got an eBay replacement, but it was junk. Plan C was to borrow a GoPro type digital movie camera with a wide angle lens, but that didn't work out either. Plan D was the regular digital camera set in movie mode. It worked OK, and has better image quality (than the web cams). Downside: not as convenient as a web cam, which I could monitor from inside the car to make sure it was working/review footage to make sure it was clear.
A nice zoom picture from the side would be helpful when you can get to it.
Sure!
Just a side note, but have you tried mounting the camera on a shorter length support
I did look at a few different angles, and I just liked this one best. Where I tested, there was no chance of hitting the boom on anything. A GoPro wide-angle camera would have permitted a shorter boom, and still given me the angle I liked.
Can you answer me a question -- how wide is your tail's "transom" / rear surface? EDIT: never mind - found the answer in your tail thread.
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
3-Wheeler (04-23-2013), HyperMileQC (04-22-2013), Stacygifford (05-03-2013)
