Old 04-21-2013, 09:18 PM   #61 (permalink)
You know, it looks like the sides curve more than the top. Could you cut panels of varying lengths and laminate them from the back to the front? Like leaf springs!
I would put the shortest piece on the inside and put longer and longer strips going out, or cover the edges with paper maché. You want a smooth edge for aerodynamics, right?
We want smooth edges because it is beautiful!
Old 04-22-2013, 12:19 AM   #62 (permalink)
Idk if u already see this or not but it does look like the second half of the side should follow the first half of the angle of curvature maybe to the middle of the tail light and not to the inside of it (I'm sure u already see that)? Can't wait to see what u do next, gives me ideas as to what to try for my tail. Thanks for the pics, helps everyone out including me!
Old 04-22-2013, 02:09 AM   #63 (permalink)
Want a cheap weatherproofing? Stickerbomb it
Old 04-22-2013, 09:14 AM   #64 (permalink)
Looking forward to the video - but from the still image it looks like the tufts on the top are slightly angled to ward the center, which would indicate the air is flowing up from the sides and over the top? So, you are likely correct that the sides are curved too much.
Old 04-22-2013, 09:20 AM   #65 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I just got a notification e-mail of Neil's reply to the thread and it hit me when I've read the name of the thread again... If this is "quick 'n' dirty" boat tail then all others boat tails are what?
I'm just so impressed by your craftsmanship Metro! Congrats again on fabricating such incredible boat tail from a piece of cardboard.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-22-2013, 11:51 AM   #66 (permalink)
90 day: 51.82 mpg (US)
tuft testing video
Well, after a good night's rest and a fresh look at the tuft testing results today, I've decided it's good enough as-is. I'm not going to change it.
EDIT: Neil, I might just test that wheel strake/boattail idea to reduce turbulence, too. If that doesn't help, when I make the permanent tail, I'll use a little less curvature in the sides, which will add about 20 cm / 4 in. to the width of the rear.
Tuft testing video: (used Youtube's "image stabilization" feature, which is fantastic! The raw video is pretty bumpy at times.)
Next task: A-B-A test and weather-proof it. Weigh it, measure it, to answer those inevitable questions.
The Following 15 Users Say Thank You to MetroMPG For This Useful Post:
ausias (05-08-2013), Cd (04-27-2013), COcyclist (04-22-2013), ECONORAM (05-02-2013), elhigh (04-22-2013), Flakbadger (04-27-2013), HydroJim (04-22-2013), HyperMileQC (04-22-2013), Jyden (04-22-2013), NeilBlanchard (04-22-2013), PaleMelanesian (04-22-2013), Piwoslaw (04-23-2013), Rokeby (04-22-2013), Smurf (04-24-2013), Vekke (04-28-2013)
Old 04-22-2013, 01:33 PM   #67 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Hi Darin,
Hey, I noticed that you used a camera this time instead of the web-cam. Is there a reason why you chose the camera?
A nice zoom picture from the side would be helpful when you can get to it. Your down-slope is slightly less severe than mine, and those tufts seem to be very steady in that area. Getting a better view of your sloping angle would be interesting.
Just a side note, but have you tried mounting the camera on a shorter length support, and viewed the tufts at a "flatter angle". All the tufts would still be placed in the "perspective" view, but would have less worries of hitting the camera on something to the side of the road.
I'm asking questions for education when I try a tuft test on the tail.
__________
That's some really fancy cardboard fashioning !! Very impressive !!
Thanks, Jim.
Old 04-22-2013, 01:52 PM   #68 (permalink)
Hi Jim...
The web cam I had been using died. Plan B: I got an eBay replacement, but it was junk. Plan C was to borrow a GoPro type digital movie camera with a wide angle lens, but that didn't work out either. Plan D was the regular digital camera set in movie mode. It worked OK, and has better image quality (than the web cams). Downside: not as convenient as a web cam, which I could monitor from inside the car to make sure it was working/review footage to make sure it was clear.
Sure!
I did look at a few different angles, and I just liked this one best. Where I tested, there was no chance of hitting the boom on anything. A GoPro wide-angle camera would have permitted a shorter boom, and still given me the angle I liked.
Can you answer me a question -- how wide is your tail's "transom" / rear surface? EDIT: never mind - found the answer in your tail thread.
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
3-Wheeler (04-23-2013), HyperMileQC (04-22-2013), Stacygifford (05-03-2013)
Old 04-22-2013, 02:09 PM   #69 (permalink)
That's a creative idea, by the way!
Old 04-22-2013, 02:30 PM   #70 (permalink)
Yay! I am useful!
