Old 04-23-2013, 09:11 AM   #10 (permalink)
Xist
Originally Posted by jeff88 View Post
The second thought was an ability to know if the fan is on. Like a little LED light that comes on when the fan is on. It could be really inconspicuous, since it probably won't be on very often, but would be useful, so you could know when/how often the fan is on. Unless of course an UG/SG has the ability to show fan on/off, then that would be the most useful
I have read about people on here doing that and I actually asked about it a couple of months ago. Here is the thread, but I will jump straight to the end.
http://ecomodder.com/forum/showthrea...led-24563.html
So, it is that easy? Find the fuse, drop in two wires, run the wires through my firewall, and mount an LED?
Sven also suggested:
Originally Posted by Sven7 View Post
If you get one of the larger (~10mm dia) lights with built in bezel you can drill a hole in a blank dash panel and it will look OEM. Loose LED's are kinda hard to mount.
Just yesterday I read a post where someone said that his car actually got better mileage with enough of a grill block that his fan needed to run more.
I hope that is enough.
