Old 05-08-2013, 11:37 AM   #7 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Originally Posted by NoD~ View Post
Just a thought: with some sort of "smart controller", one would be able to eliminate the need of a thermostat, wouldn't they? Having the water pump only kick on at a specific temperature and turning off completely (or just reduced speed) once cooled to another specified temp?
Sounds good to me! With a controller, I bet fuel savings would for sure be seen. Would a micro controller work for this?
If one had an openable grill block, they could even have the block open when the water pump comes on for a more efficient cooling.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
