Originally Posted by turbovr41991
Congrats on the high numbers! Sounds like you have a lot of stuff that needs attention. (I know the feeling...) Are there other transmission options for the 01? I know 92-00 interchange so the cx/VX trans is ideal for our gen, but not sure about newer ones. Since you are already doing the work, it is probably worth a little research to see if there is anything that would swap in cheaply.
Also, I went with Koni orange shocks. They are oem ride quality and carry a lifetime warranty. When put them on, I went ahead and got some conservative lowering springs as well to lower the drag of the car.
For the 7th gen, The HX tranny has the highest gear ratios. I have an HX. I also have a replacement HX transmission that's been rebuilt. I just have to put it in.
I have a line on a set of Ground Control coilovers that are going cheap. However, the ad is light on details and there are actually
nine different versions of these for 7th gen Civics... hopefully they will work. If that doesn't pan out, it's getting lowered via non-adjustable lowering springs. The earlier generations are a LOT easier to figure out which suspension parts work with your car.
The Koni STR.T (orange) struts/shocks are what I will use unless I find a great deal on something else.
