Old 05-17-2013, 06:22 PM   #309 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by RatherDashing View Post
after doing a lot of research about the Honda mtf and using regular oil. Honda MTF has additives in it specially made for the transmission rather than just using regular oil. I replaced my fluid with Honda mtf and it shifted smoother and wasn't leaking as much as regular oil was which was in there.
The additives, from what I read at - Bob is the Oil Guy, are mainly about wear and I wouldn't imagine they'll make any difference with shifting quality or leakage from the axle seals. I am getting slight leakage from one axle seal, which I think is because I seated it too far into the transmission. I need to adjust and will do that shortly when I replace the hub bearing unit on that side.
I also think, given how gently and low rpm we drive these transmissions, that the differences between Honda MTF and high quality synth oil like Royal Purple are negligible, personally. And the Royal Purple is cheaper by far.
