Old 06-19-2013, 11:04 AM   #16 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I can see low pressure with a car sitting on top of it, allowing deformation and reduced diameter. Higher pressures really shouldn't stretch the steel belts past nominal size. I'd think higher pressures would increase resistance to deformation (=LRR) without an actual increase in diameter.
This doesn't account for people like Ford specifying really low pressures in their Firestones for a cushy ride, but if reasonable people set the spec, going to max sidewall or beyond shouldn't affect size.
This makes sense, but I think Pale still has a point. If the OEM psi spec is low enough to allow deformation under the car's weight (which it does of course) then higher pressure might help the tire keep more of its max design diameter. If the car makers factor the deformation into their expectations for the odometer/speedometer, then wouldn't higher pressure produce fewer revs per mile? What am I misunderstanding?
