Old 07-10-2013, 06:58 PM   #154 (permalink)
oil pan 4
What is so wrong with taking the typical electric vehicle that has well under 100 miles of range and pulling a liquid fuelled generator trailer behind it?
You could supply say up to 10 to 12kw (the smallest 3-phase generators I commonly see) with a small engine fuelled with any fuel you want.
The cheap versions would burn regular old gasoline. Higher end ones could burn biodiesel, SVO mixes, alcohol or LPG.
Service stations, equipment rental places and U-Haul would be good places to rent them from if you didn't want to buy one.
