Old 07-16-2013, 03:12 PM   #30 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Installed the clips. I did some low speed round-the-block testing. Maybe brake drag is reduced. I cannot tell for certain. Any improvement might be in the range of data noise? Or maybe that soft non-squealing metal on metal sandy -sound that I introduced is increasing drag. It's a very mild sound. But clearly one or two of the eight total possible contact points are in fact slightly skimming the rotors. Gotta go back in. Oh well.
They should fit. Before installing I searched the part number on the bag "H6001." Raybestos indicates that these clips fit the "1998 Honda Civic". And Amazon lists them as fitting my DX exactly, though they oddly also highlight the EX/Si (no mention of HX).
So they should fit. The error is mine, right? Any advice welcomed...
[EDIT: on a ten mile each way half freeway trip I noticed all sounds seem to go away at higher speeds. Maybe just drowned out by road noise. But after driving a higher speeds the sounds are gone even at lower speeds. Sometimes felt like a super quiet amazing coaster on rails (no brake friction noise. Still, will fine tune.]
