Old 07-17-2013, 04:07 PM   #12 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
I'm wondering how you would oil this engine, since gravity is working against you, how would you make sure the top side of the cylinder gets oiled properly and how do you get return oil back into the pan without getting on things that it shouldn't?
Also, what would a horizontal do to the efficiency of the engine as opposed to a vertical? Would the horizontal engine be able to turn the crankshaft (or whatever term) using less energy?
Originally Posted by wdb View Post
It seems to me that the biggest benefit is that the cam's rotating masses cancel one another, which may make for a smoother running engine. (A six cylinder version would wipe that out of course.)
How would a six not be smooth like a 4? Wouldn't it still have a rotating mass to cancel each other out? I would think this engine design would be really bad with an odd number of cylinders, but not 6.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
