Had other stuff that needed doing the last couple of days so not much time for the car. I did manage to get it about 3ft in the air though
Takes nothing to pick the car up since any frame member can support the entire car. I could hook to the back bumper and lift the whole back end the same as I did the front. I could also hook to the side bars inside the doors to lift the side of the car up. If it was possible to get to the bar in the dashboard I bet it is probably near the center of gravity and I could lift the entire car at once
Also I have some side skirts to play with now and I just picked up four 4x8 sheets of coroplast for the belly pan. So it looks like the last of the big work for the car should be done this week. One thing I was thinking though is how does everyone make or mark out jacking points on their underbelly so they can jack the car up in the future. I really don't want to have to drag the engine hoist out every time I need to take a tire off
