Old 07-21-2013, 01:29 PM   #172 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Well, the ForkenSwift's twin motor is sitting here (kept it as a spare). 110 lbs series wound, built like a brick ... outhouse. Come get it!
Originally Posted by mechman600 View Post
The growing TO DO list on the Electric Booger is becoming quite long.
That's quite the list. I've stopped keeping lists... easier than solving pathological procrastination.
the vacuum pump runs for a second each time the brakes are applied.
Funny - I never noticed the pump running when we went for a drive. Must not be horrifically loud. (FS really needs a pump too. Will get one if I turn it into a pusher.)
Which is the better option??
I think a fan that ran every time I pressed the go pedal would bug me. What about a combination: thermo switch so it only runs when hot AND you press the pedal?
13. Lower grill block - I cannot believe I haven't done this yet. That's all I have to say.....
I never have either - but the FS's average speed is likely ~20 km/h.
