Originally Posted by cbaber
(b) Whenever the Department of Transportation determines on the basis of an engineering and traffic survey that slow speeds on any part of a state highway consistently impede the normal and reasonable movement of traffic, the department may determine and declare a minimum speed limit below which no person shall drive a vehicle, except when necessary for safe operation or in compliance with law, when appropriate signs giving notice thereof are erected along the part of the highway for which a minimum speed limit is established.
Make sure you stake your claim when you see a survey counter. Be civil and courteous though. Extreme readings will be eliminated with statistics. A collective economical movement could create a significant impact on minimum laws.
Even with this clause it states the "except when necessary for safe operation or compliance with the law."
Safety trumps arrogance when the law is concerned.
