Originally Posted by aharvey
I think you still have the brightness settings in debug mode on github. The brightness array doesn't have 0 as the first element. Other than that, I was able to load it up, and I'll see how it works tomorrow. Good work, and thanks!
Hm... It never has had zero as the first element. I checked the repo and even back to the first change I made in April '09... I'm assuming you can't get the backlight to turn off after flashing this...?
