Old 09-13-2009, 09:23 PM   #21 (permalink)
Originally Posted by orange4boy View Post
Are there any issues with using the earlier versions of arduino?
Can you just flash the chip with the older versions of the code like .75
Where / on which program would I see the data on a mac?
Should be no issues going back to 0.75.
If you plug the MPGuino into your computer, and then fire up the Ardunio IDE, you should see the data appear in the debug window there.
Old 05-20-2010, 02:44 PM   #22 (permalink)
HI! I know its been a while, but where can i find a full code for MPGuino? With full, I mean, all code hacks, this tank memory thing, distance to emty etc etc... i am not very advanced with programming so my code hacking is quite unsuccessful
can someone post a fully modified code? or send me e-mail to burritto AT inbox DOT lv
very much appreciated
Old 03-09-2011, 07:11 AM   #23 (permalink)
Bix
Even though its now 2 years late, but does anyone have the code for this? The bar graph and saving to eprom sounds interesting.
Old 03-29-2011, 04:38 PM   #24 (permalink)
mcmancuso's Avatar
Green Metro - '99 Chevrolet Metro LSi Sedan
90 day: 32.78 mpg (US)
Metro Vert - '91 Geo Metro LSi Convertible
90 day: 50.52 mpg (US)
I and others are working on implementing this into the new firmware, check the release 2 workspace thread
Old 07-26-2013, 01:02 AM   #25 (permalink)
I've been gone for a while. I sold my Mazda Protege5 a couple of years ago and bought a 2010 Corolla. The Corolla already had a fuel economy readout so the MPGuino was rolling around in my glovebox for a couple of years.
I just bought a '06 Wrangler and I resurrected the MPGuino a couple of days ago. It is installed and working like a champ.
I've posted all of the code changes from this original thread to github:
https://github.com/skelliam/mpguino_fork
So what is going on with MPGuino, is dcb still around and active with it?
One thing I learned after installing the MPGuino is how to get into fuel cut mode. In my Mazda Protege5 with manual trans it was quite easy, and you could hear and feel when it was happening. Jumping to the Corolla, it was also really *really* easy to get into fuel cut mode, even during cruise control if you were going SLIGHTLY downhill you could feel fuel cut happening.
My Wrangler, not so much. I had it for about a week before installing the MPGuino and I had definitely the suspicion that it was not entering fuel cut mode at all. After installing the MPGuino I could confirm that suspicion -- but also I learned that it *WILL* enter fuel cut mode but only under very extreme conditions, like very high engine rpm off throttle. In 5th or 6th gear, coasting, it simply won't enter.
Anyhoo, enough rambling, fork and hack away on my github repo if you are so inclined. Sorry it has been so long.
Old 08-11-2013, 10:13 PM   #26 (permalink)
I think you still have the brightness settings in debug mode on github. The brightness array doesn't have 0 as the first element. Other than that, I was able to load it up, and I'll see how it works tomorrow. Good work, and thanks!
Old 08-12-2013, 11:41 PM   #27 (permalink)
Hm... It never has had zero as the first element. I checked the repo and even back to the first change I made in April '09... I'm assuming you can't get the backlight to turn off after flashing this...?
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 02:37 AM
Newly assembled Spiffed Kit, Backlight but No Display osme OpenGauge / MPGuino FE computer 9 04-30-2009 07:26 PM
No display on MPGuino LCD, just backlight Wingmn OpenGauge / MPGuino FE computer 27 02-06-2009 07:27 PM
Got my MPGuino Working! Nevyn OpenGauge / MPGuino FE computer 0 12-07-2008 05:38 PM
Help w/ mpguino space shuttle code please forgottenmindset OpenGauge / MPGuino FE computer 14 09-07-2008 04:17 PM
