Why would you switch to rear drive when the front drive bits are completely unaffected by the mod?
Granted hacking off a few hundred pounds of steel and cutting your aero drag way down would make a much taller top gear look pretty appealing, if it can be done. Is there a taller fifth gear available, maybe for the *ahem* sporty, high-powered model of Cav?
