08-14-2013, 07:42 PM
#11 (permalink)
"Cavalier trike"
08-14-2013, 08:10 PM
#12 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
Originally Posted by Frank Lee
that looks and sounds just like it.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
08-15-2013, 12:25 AM
#13 (permalink)
Think about that some more, because it's downright silly.
Sure it wouldn't be the smartest move to relocate the engine to get a chain-driven RWD layout in this tricycle, but I've already seen similar setups in artesanal motorcycles fitted with car engines
08-15-2013, 09:36 AM
#14 (permalink)
The driver of that car looks a little like the actor in the movie Repo Man (1984), the one with the bi-polar glasses, one side blacked out.
the phantom country: May 2013
A few years have gone by, could be.
08-15-2013, 01:24 PM
#15 (permalink)
Originally Posted by cRiPpLe_rOoStEr
Who never considered a similar project?
Everyone who really wanted one, has built his own, I guess ...
08-15-2013, 02:11 PM
#16 (permalink)
Or maybe didn't have either time or the space required to work on a similar project. I've been lurking to do a similar project for quite a long time, but still didn't have the time.
08-24-2013, 11:01 AM
#17 (permalink)
Master Novice
Why would you switch to rear drive when the front drive bits are completely unaffected by the mod?
Granted hacking off a few hundred pounds of steel and cutting your aero drag way down would make a much taller top gear look pretty appealing, if it can be done. Is there a taller fifth gear available, maybe for the *ahem* sporty, high-powered model of Cav?
08-25-2013, 12:39 AM
#18 (permalink)
To increase the challenge?
But sure, it wouldn't be the smartest move. Altough an auxiliary electric motor in a setup similar to the XR3 could be a nice improvement, and also helping to deal with weight balance concerns...
08-25-2013, 12:50 AM
#19 (permalink)
What weight balance concerns?
08-25-2013, 12:55 AM
#20 (permalink)
Less weight in the rear-end, so eventually if brake loads weren't correctly balanced that could have a rear-lift.
This way:
