Old 08-26-2013, 07:41 AM   #343 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Vekke View Post
Wheel + tire 145/80R14 weight is now ~9 kg with 1mm thread depth left. So there is not much to lighten there.
Got that right. What a cool wheel.
Do you know its other specs? Offset, bolt pattern, lug size, and center bore? On "wheel-size.com" is see:
155/65 R14 6x14 ET45 4x100 mm Bolt: 12*1.5 57.1
Is that right? If so, it suggests the Lupo wheels would probably fit a 1992-2000 Civic with the addition only of 1mm spacer rings because the Lupo center bore is larger.
