Old 08-28-2013, 02:48 PM   #5 (permalink)
oil pan 4
Originally Posted by lselse3 View Post
Iv found that by simply installing a couple large batteries in the back (next to the water tank for HHO and the cell), one may turn their car into a plugin hyrbid. The "plug in" coming from charging the batteries with a wall charger each night. This system is much cheaper and simpler to build and install than a Hybrid electric modification, and it easy to remove, should the need arise.
Why not do an alternator delete with all that extra battery capacity?
Alternator deletes have proven to give around a 10% boost in fuel economy, where HHO seems to provide no boost in fuel economy.
If you are going to make the effort you might as well do some thing that will give you something in return.
1) Directly using that battery power via an electric motor would be much more efficient.
Yes, by far.
